PostPosted: Tue Mar 25, 2008 12:35 pm
Do you have to change the bell housing to a standard nose cone shift style in order to use the standard T1/T2 flywheel?
PostPosted: Tue Mar 25, 2008 4:56 pm
[quote='Odyknuck']Do you have to change the bell housing to a standard nose cone shift style in order to use the standard T1/T2 flywheel?[/quote]
No, but the later (6-rib) and side shift transmissions use a different starter (called an 091 starter)
PostPosted: Tue Mar 25, 2008 9:44 pm
I wa saware of the difference betrween the sedan/002 and the 091 starter. The bell housing on th e6 rib is thicker. I read a popst on the Samba stating the Vanagon used a larger diameter (228MM over the 200MM) flwheel than the 091 and thats why I asked.
PostPosted: Wed Mar 26, 2008 7:25 am
The Vanagon did use a bigger f/w, but the regular (200m) vw one will work fine as well.
PostPosted: Wed Mar 26, 2008 9:48 am
So I take it the OD of the ring gear is the same for both.
PostPosted: Wed Mar 26, 2008 12:20 pm
are you refering to the bellhousing on the sideshifter trans? ( the two bosses at the bottom?)
PostPosted: Wed Mar 26, 2008 12:26 pm
WOW Thats what I call tongue tied.
The Wild Kids
PostPosted: Wed Mar 26, 2008 1:24 pm
You need a Bosch SR 87 starter Steve.
The drive sticks out further to reach the flywheel.
Not a good picture but you can see the teeth are out further on that longer shaft.
This is a SR15 starter used on most other trannies.
The teeth are right up against the starter body.
PostPosted: Wed Mar 26, 2008 2:43 pm
Gary I have the hipo 091 starter, my concern was the ring gear outside diameter on the Flywheel not meshing with the starter gear.
PostPosted: Wed Mar 26, 2008 4:23 pm
[quote='Odyknuck']Gary I have the hipo 091 starter, my concern was the ring gear outside diameter on the Flywheel not meshing with the starter gear.[/quote]
I am not sure about the outside diameter of the bus f/w, but I do know that the part of the housing that centers the engine is the same size as the type 1. In other words, a t1 engine fits into the housing just like the bus engine does.
