It is currently Mon May 04, 2026 5:29 am
 Post subject: Parts question
PostPosted: Thu Jan 16, 2014 7:19 pm
Gonna have a 456 put together with 4diff what's some things I could buy from weedle to make it strong as possible other than buying gears
 Post subject: Re: Parts question
PostPosted: Fri Jan 17, 2014 4:03 am
well short of busting it all the way down and installing new roller bearings, tapered bearings and hand packed needle bearings, in addition to the 4 spider diff, i would get a chromoly pinion nut, torsional input shaft and mainshaft bearing retainer plate or whatever its called that goes between the nose cone and gear carrier/mid section
PostPosted: Fri Jan 17, 2014 4:13 am
Ok will look into that once im home thanks
PostPosted: Fri Jan 17, 2014 7:29 pm
a chromoly diff cover
PostPosted: Fri Jan 17, 2014 11:40 pm
Steel shift ball for the hockey stick.
PostPosted: Mon Jan 20, 2014 9:31 pm
Fabricate a 1/8 inch plate like this one between main case and bellhousing to help stop case spread.
PostPosted: Tue Jan 21, 2014 6:58 am
I BELIEVE THE SPREADER PLATE IS A GOOD IDEA; DAMN THAT WAS FUN!!!!
PostPosted: Tue Jan 21, 2014 8:06 am
Charlie, did you notice the chainsaw next to the hole in the steel plate? Ask your mom for 1 of those next Christmas! Had some gamewarden/hunter issues at leeds Sun. Going to Flipindale this week end. Deer season is over at the end of this month.
PostPosted: Tue Jan 21, 2014 11:21 am
Yea I noticed wondered if he used it with a titanium chain I'm riding somewhere for sure have to check my buggy bag to see if I have enough funds LOL !!!!!!!!!!!!!!!!!!!!!!"!!!!!!!!!!!!!"!!!!!!!!!!!!!!!!
PostPosted: Tue Apr 21, 2015 8:48 pm
Regarding that plate. Y'all say 1/8" inch plate to stop the case from spreading. Would ar plate be good to make it out of or would that possibly be to hard. I know its some tuff stuff because even when its red hot its hard to bend. We use it for build the floors of our trash trucks and I manage to get some cutoffs from time to time and I just picked up 2 good size pieces awhile back. And is there any other modifications to the case needed to do this. I'm asking because I just picked up a side shift a few weeks back and the more I can do myself the better.
PostPosted: Wed Apr 22, 2015 4:42 pm
AR plate won't add any strength in that application. I don't know if you've drilled any AR plate, get ready to hate the idea of using it.
If your adding this plate you might as well use it as a mounting plate as well, add a couple of ears down low and drill a couple of mounting holes.
PostPosted: Thu Apr 23, 2015 1:36 pm
Yeah Mike I've drilled it before and your right it's no fun. I just figured I have more time than money and the plate was a freebie and also thought about using it for a mount plate. I've also got a piece that is just right for a skid plate too. I guess it just me taking after my old man and being cheap.
PostPosted: Thu Apr 23, 2015 2:07 pm
Frugal. Fiscally responsible. Monetarily challenged.
