It is currently Sun May 03, 2026 3:34 pm
PostPosted: Tue Nov 18, 2014 3:40 pm
I just have a quick question before I pull the trigger and she'll out some money. I found an 091 trans with a type 2 bell housing that came out of a running van that was converted to electric for $275.00. Is this a good deal or not. I'm new to buggy and on a budget and don't want to spend money that's not nessicary. I plan on installing it into my 4 seat family buggy when I switch to irs.
PostPosted: Tue Nov 18, 2014 4:07 pm
If it's in good shape then yea it is
PostPosted: Tue Nov 18, 2014 5:35 pm
Thats a good deal on any budget.
PostPosted: Tue Nov 18, 2014 6:17 pm
What does "Converted to Electric" mean?
PostPosted: Tue Nov 18, 2014 6:43 pm
What motor are you going to run on it , and how do u plan on driving the buggy ?
If you cant fix it with a hammer it aint worth fixin!!!!
PostPosted: Wed Nov 19, 2014 3:09 pm
Well Matt I've been stocking up vs parts for the last couple of years cause my wife bought me a 2 seater a few years back and it's a real basket case. The frame needs a lot of work and the case had a rod put through it a one time and one of the previous owners filled it with jb weld. So I have enough parts on hand to build a 1600. Just hadn't messed with it because love got in the way and had to many irons in the fire. Then a few months ago I came across my 4 seater and it was in a lot beater shape so I hauled it home found that the engine was bad on this one too. So I figured I'd go overboard on this one first. And I will be running this one as hard as possible until it breaks. And mike he basically took a perfectly good van and made it an over sized golf cart I guess. When I talked to him on the phone he sounded kinda out there.
PostPosted: Wed Nov 19, 2014 3:11 pm
I'll be starting a build thread as soon I can figure out how to post pics. I've already started by starting to widen the link pin beam and add 10 inch towers and gussets to the spindles and carriers.
PostPosted: Mon Nov 24, 2014 6:06 am
OK got it figured out now so I will start a build thread in a few days before I get to far into it.
