It is currently Mon May 04, 2026 5:47 pm
PostPosted: Fri Mar 28, 2014 9:48 am
I have a 6rib in my buggy now and I'm switching to 3 rib for the lower gears but I don't have a 3 rib starter will the bellhousing from 6 fit the 3rib thabks
PostPosted: Fri Mar 28, 2014 11:54 am
I know a lot of people put the 3 rib housing a 6 rib trans but I have never heard of anyone doing the reverse.
I would check the input shaft on a 3 rib to make sure it is long enough to work with the 6 rib bell housing.
PostPosted: Fri Mar 28, 2014 7:59 pm
Yes it will work but you need to swap the input shaft.
