It is currently Mon May 04, 2026 5:47 pm
 Post subject: 6 rib drive flange play
PostPosted: Fri Jan 10, 2014 3:18 pm
How much is normal?
PostPosted: Fri Jan 10, 2014 3:35 pm
Transmission Was a little low on fluid also.
PostPosted: Fri Jan 10, 2014 7:28 pm
I'm not sure on the play but I run mine a little low fluid so when I'm climbing steep hills it doesn't leak around the input shaft and get on the clutch and make it slip
