It is currently Mon May 04, 2026 5:47 pm
 Post subject: 6 Rib question
PostPosted: Mon Sep 16, 2013 2:00 am
Are all 6 rib trannys considered the 091? Or is there a 091 and a 6 rib?
 Post subject: Re: 6 Rib question
PostPosted: Mon Sep 16, 2013 7:26 am
There a all 091 just nose cone shift or side shift
PostPosted: Mon Sep 16, 2013 1:14 pm
I thought that side shift is 094 and the nose cone is 091 they both are 6 rib
PostPosted: Mon Sep 16, 2013 1:36 pm
You Are right sorry :oops:
PostPosted: Mon Sep 16, 2013 6:31 pm
Cool thanks
PostPosted: Mon Sep 16, 2013 7:33 pm
The side shift ad standard mid shift are 091. The 094 is a mid shift 5 speed.
PostPosted: Mon Sep 16, 2013 9:44 pm
This is an 094 6 rib:
http://www.weddleindustries.com/transax ... ty-vanagon
This is a 091 6 rib:
http://www.weddleindustries.com/transax ... ransaxle-0
PostPosted: Tue Sep 17, 2013 4:43 pm
I got a few mid shifts Dave and they all got 091 in the #
PostPosted: Tue Sep 17, 2013 10:02 pm
It all depends on who you are dealing with. Weddle calls the 091 case shift an 094 4 speed so that is the term that we use. Any other 091 has a small reverse gear and is weaker in several areas than an 091 case shift(094 4 speed).
I dot not believe that there is much difference between an 091 nosecone shift and an 091 sideshift (Not in case)
But the 091 case shift(094 4 speed) is another animal.
Good Luck
Kenric
