It is currently Mon May 04, 2026 5:47 pm
 Post subject: thing cv's
PostPosted: Tue Aug 20, 2013 1:00 pm
Experience with thing cv's 'vs' bus cv's whats better ?
 Post subject: Re: thing cv's
PostPosted: Tue Aug 20, 2013 2:15 pm
This is where I got my 930s if you could luck out an get them for 300 that would b a good deal.
http://item.mobileweb.ebay.com/viewitem ... 0646736486
PostPosted: Tue Aug 20, 2013 3:11 pm
Thing and bus type 2 are identical. A 930 cv will tale more angle than a type 2 and is stronger due to the width and larger ball bearings.
PostPosted: Tue Aug 20, 2013 3:23 pm
They are not the same. I've had good luck with both.
http://www.blindchickenracing.com/how_t ... ts_101.htm
PostPosted: Tue Aug 20, 2013 4:28 pm
you can use the vw Jetta inner 100mm thats what i use :)
PostPosted: Tue Aug 20, 2013 9:27 pm
The thing cv is a type 4 and a bus is a type 2. They are the same except on the type 4 it has a larger opening on on the outer part ( where the axle splines into ) of the cage and runs a smaller ball so it has more articulation. The bus runs out at 17 degrees and the thing type4 runs out at 22 degrees.the thing cv is also just a little thicker I mean it's still a 100mm circumference but a little bit longer so I guess I should have just said they are not the same,lol. Chad :mrgreen:
PostPosted: Tue Aug 20, 2013 10:21 pm
So do you think. that the ball bearings are smaller would make the type 4 stronger than the type 2
PostPosted: Wed Aug 21, 2013 10:56 am
Conventional thinking would be that the larger ball CV type 2 would be stronger which is why VW developed them for the heavier bus. Thing CV's were designed with more angular deflection and the balls are between car and bus in diameter size and for a buggy are strong enough. One other thing to consider is if you build your buggy to use type 2 CV's they are easier to come by out in the pucker brush when you need to borrow one. JMHO
PostPosted: Wed Aug 21, 2013 12:53 pm
So are these like a bus or a type 4 ?
PostPosted: Wed Aug 21, 2013 8:33 pm
Ok my point is the type 4 or thing if you will has a stronger cage because of the smaller balls.the bus cv cage is not as thick because of the larger balls.and the type 4 and type 2 use the same flanges. Plus you get more angle out of type 4
PostPosted: Wed Aug 21, 2013 11:27 pm
I ran type 4 cv's on my old buggy for 6 years and never had a failure. I sold the buggy to rail1914 last year and they are still going strong.
PostPosted: Thu Aug 22, 2013 4:21 am
The smaller ones always seemed better to me
PostPosted: Thu Aug 22, 2013 9:28 am
I did a quick check of wall thickness at the bottom of the ball groove and the type 2 is .412 and the type 4 is .439 which is .027 more for the type 4. I've seen lightened 930's for racing and am curious how thick they end up being.
PostPosted: Thu Aug 22, 2013 3:00 pm
When you find out let me know thanks for the info :D
PostPosted: Thu Aug 22, 2013 10:25 pm
If it has bigger balls. Well you know what I mean.
Kenric
PostPosted: Thu Aug 22, 2013 10:30 pm
Kenric
Its not in the balls lol
