 Post subject: la products
PostPosted: Mon Jul 08, 2013 3:53 pm
Has anyone had any transmission work done here would like any feed back on them before I take it there.
 Post subject: Re: la products
PostPosted: Mon Jul 08, 2013 4:26 pm
Where would you recomend I take it?
PostPosted: Mon Jul 08, 2013 4:39 pm
Not sure where you are located but I would go to Chuck Jones..
PostPosted: Mon Jul 08, 2013 5:00 pm
Like Mouse said OR Eric DeBoard
PostPosted: Mon Jul 08, 2013 5:12 pm
where are they both located?
PostPosted: Mon Jul 08, 2013 5:37 pm
call brian he's in east canton ohio 330 488 0715 . he did a good job on my transaxle
PostPosted: Mon Jul 08, 2013 11:23 pm
Who all has gone to brian? I heard a lot of bad about hI'm.
PostPosted: Mon Jul 08, 2013 11:58 pm
What's wrong with your tranny, alot of guys on here can replace a gear or two or change out a diff?
PostPosted: Tue Jul 09, 2013 12:01 am
I just need that diff installed
PostPosted: Tue Jul 09, 2013 12:09 am
You are in Streetsboro, Ohio, hopefully someone local will see your post and help you out.
That's like a 45 minute job in the bug, if you have the engine and axles off the tranny.
Like $50
PostPosted: Tue Jul 09, 2013 11:15 am
I am in warren Ohio and could install a diff thats the easy part or I would recommend taking it to Jim's custom VW he does good work and will not try to sell you everything you don't need .
PostPosted: Tue Jul 09, 2013 3:09 pm
brian has built several trans and two engines that i know of ( people i ride with ) AND HAVE NEVER HEARD COMPLAINTS
