It is currently Mon May 04, 2026 2:39 pm
 Post subject: six rib bell.
PostPosted: Thu Feb 21, 2013 9:05 pm
How much do u mill off a six rib bell to fit bug starter? Anyone ever done this . Thanks
 Post subject: Re: six rib bell.
PostPosted: Thu Feb 21, 2013 10:56 pm
Get a bus starter! Then when you want to go big AC or WC then you can run the 9" clutch, once you mill about a 1/2" off its gone for good.
PostPosted: Fri Feb 22, 2013 6:46 am
I have heard of people running a 3 rib bell housing on a six rib trans but I have never heard of anyone modifying a 6 rib bell housing.
If you run a 3 rib bell housing, I believe you will need to cut a little bit off your input shaft.
PostPosted: Fri Feb 22, 2013 10:35 am
Or Swap the input shaft for the 002 input shaft.
PostPosted: Fri Feb 22, 2013 11:07 am
Just put the 3 rib bell on and your ready to go. Don't need to change anything.
PostPosted: Fri Feb 22, 2013 4:42 pm
Depends............There are 3 different 3 rib bellhousings.
PostPosted: Fri Feb 22, 2013 5:36 pm
I'm pretty sure you have to remove 1/4" off the starter surface. I don't have a spare 3 rib bell to measure though.
PostPosted: Fri Feb 22, 2013 5:41 pm
just measured my 3rib bell thats in my buggy with a tape measure. It's hard to get an exact measurement but looks close to 2-3/8" from outside bell edge to outside starter edge.
