It is currently Mon May 04, 2026 11:46 pm
PostPosted: Mon Nov 05, 2012 7:41 pm
Long title, I know. I'm running the side shift 094 transaxle with Davis Motorsports linkage. I also have a Scat Dragfast shifter. I'm not sure if this is a shifter problem or just a conflict between this shifter, linkage and transaxle. I couldn't get second when I could get first and reverse. When I adjusted to get second I couldn't get first or reverse. Third and fourth seemed fine throughout this testing. The sifter didn't have enough throw to get all the gears. Finally I took it off the car and ground out the edges/stops on the shifter base. When the ball would throw forward it hit the edge of the base plate, same with the backwards throw. I removed a little material off the base plate and allowed the shifter to move farther. Put it back on the car and bam, all 5 gears.
Just thought I'd save someone a headache if they have a similar combo missing a gear.
