 Post subject: trans question
PostPosted: Tue Aug 02, 2011 10:58 pm
im trying to turn a side shift 6 rib into a tail shift only using the main case. but the side shift case is not drilled and tapped for fill plug. does any body know what size tap i need to use on the case?
 Post subject: Re: trans question
PostPosted: Wed Aug 03, 2011 8:43 am
I'd just tap it for a 3/4 pipe plug.
PostPosted: Wed Aug 03, 2011 8:52 am
second that! I assume your using an early nose side shifter and not the water cooled style.
PostPosted: Wed Aug 03, 2011 6:03 pm
thanks for the help guys
PostPosted: Sat Aug 06, 2011 9:26 pm
I think it is 24m X 1.5. But you can also use a 1 inch hole saw and rubber "freeze" plug. Unless you want to pay 80 bucks for the tap like I did, lol
