PostPosted: Mon Jun 28, 2010 1:03 pm
Hi Guys
I have a dule cnc master cyl. pedal set and I have a 3/4 "master ctl. for the rear disk brakes.
Will a 5/8" bore cyl. be good for the front that is drum right now but will be changed to disk later on ?????
MoblMec
PostPosted: Mon Jun 28, 2010 2:49 pm
They will be good up until you put disks on front. Then the fronts will get soft. However you could leave the 5/8 bore on the front and have them be soft so that the rears are more biased. Thats what you want anyways. Do the pedals have a balancing bar on them? If so then change out the front master when you put the disks on then adjust accordingly.
