 Post subject: Front Flex Hose, HELP!
PostPosted: Sat Jun 12, 2010 7:33 pm
So, i managed to snap off a front flex hose way over by mf'er mem. weekend. So i call summit, because it is still u nder warranty, well they conveniently no longer stock that item. It was an earl's performance 3/8-24 male to 3/8-24 female 20" stainless braided flex line.... my problem is i can't find anymore flex lines with 3/8-24 fittings, which is what fits my buggy. can i just get -3 an and get adapters to 3/8 24 male and female? do they even make these adapters? the idiot at jeg's kept telling me i was trying to buy a brass union, they are just as retarded as summit employees!
Give me some clues, i'll even just run rubber flex lines if they make them straight to straight in 3/8 24
or even an adapter that will go from 10mm metric male to pipe thread male or inverted thread male and ill put a stock vw line back on....
PostPosted: Sat Jun 12, 2010 7:47 pm
theres a earls here in indy the web is www.earlsindy.com the info is 302 gasoline alley indianapolis in ph# 1800331indy 3172410318
PostPosted: Sat Jun 12, 2010 8:40 pm
You can try NAPA heavt duty truck shop they make lines in the shop just tell them what u need and most of the time they have everything in stock the one i go to is on gilcrest in mogadore/ellet tallmadge area
PostPosted: Sat Jun 12, 2010 8:43 pm
Heres the adress 2700 gilchrist rd akron ohio ph# 330-798-4124
PostPosted: Sun Jun 13, 2010 8:47 am
jeff , their is a company here in wadsworth that is called fine lines , they can make any brake line from stainless to rubber to factory bent lines in stainless for a 57 chevy ! I beleive they repair stainless lines also ! i have a bud that works their if you need more info .
good luck jason
