It is currently Mon May 04, 2026 10:15 am
PostPosted: Sun Mar 28, 2010 12:05 pm
Hi guys
I bought a dule cnc pedal setup with no master cyls.
Now am looking for master cyls. I found a 1 inch bore size but my question is will that be too big for the
nissan centra front calipers that I have on the back of my buggy???
Thanks
MoblMec
Tim
PostPosted: Sun Mar 28, 2010 12:34 pm
Very good question, some say the smaller the bore on the master the less pad needed. I would really like to know too.
PostPosted: Sun Mar 28, 2010 5:35 pm
Larger bore master = shorter stroke but you need to push harder.
Smaller Bore master = Longer stroke length but will create more pressure.
Not sure how much you need for the sentras, but I need to get some for front calipers.
PostPosted: Mon Mar 29, 2010 7:58 am
3/4" bore with the sentra calipers bled out good and you should have a good feelin foot pedal.
PostPosted: Mon Mar 29, 2010 6:53 pm
OK
I bought a cnc tall master cyl. with screw off top new off ebay for $20 so I thought I did good
But the bore size is 1 inch think that will be ok for sentra calipers on the rear or will it be a too stiff
pedal???
What do ya think?????
Thanks
MoblMec
Tim
Should be great. Bigger the bore on m/c , less pedal travel.
