It is currently Mon May 04, 2026 7:39 pm
PostPosted: Sun Nov 22, 2009 9:56 pm
I am upgrading my rear brakes and have seen some rotors cross drilled,,Who has done this? How did you get the pattern,,,what size holes? Are they braking better,,or are they cracking?
PostPosted: Sun Nov 22, 2009 11:33 pm
I did mine years ago, just used a magic marker to lay out the lines in a swirl pattern for 3 rows of holes.
It helped some,but what really helped was mounting calipers off a 87 suby front that had emergency brakes, and pads 4" long. I like having my emergency brake, makes me worry less.
PostPosted: Mon Nov 23, 2009 2:52 pm
Just a thought, would the holes in the disks capture and hold mud.. Causing more wear on the pads..
PostPosted: Mon Nov 23, 2009 3:00 pm
You want directional slots. Holes just cut wieght and look cool.
PostPosted: Sun Mar 21, 2010 5:48 pm
Holes do indeed just trap mud, you want these:
8)
We've used 'em over here for years, scrapes all the mud and water off the pads + discs without the risc of cracking under heavy braking.
