PostPosted: Sun Jan 10, 2010 12:31 pm
I need 2 good res's for Brake and Clutch. I think due to the S-10 calipers I need something with some piston mass. What do you guys recomend and where to find it?
PostPosted: Sun Jan 10, 2010 12:42 pm
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=10&t=4775
I kind of hit on that topic awhile back. CNC makes any size bore you need. If your looking to get by cheap look on ebay. There are always a ton of race car take-offs on there. cnc, wilwood, howe, girling...
What size bore are yopu running now :?:
PostPosted: Sun Jan 10, 2010 12:52 pm
Stock replicas I believe. A full pump isn't enough to fill the pistons so I need 1"+ I believe.
PostPosted: Sun Jan 10, 2010 1:11 pm
A residual valve will probably cure the problem.
PostPosted: Sun Jan 10, 2010 3:56 pm
I don't have front brakes so not sure how that will help. plus I also have leakage at the existing res.
PostPosted: Sun Jan 10, 2010 4:43 pm
He said 'Residual valve not proportion valve .
a Residual valve will hold a small amount of pressure on the system so you don't have to pump
and also if you get too big of a bore you will have to stand on the pedal with booth feet to make enough pressure to stop
smaller the bore ...more pressure to the calliper
PostPosted: Sun Jan 10, 2010 4:48 pm
$17 bucks Summit
PostPosted: Sun Jan 10, 2010 11:40 pm
aahhhhhh, ok. Still need resevoirs that don't leak.
PostPosted: Mon Jan 11, 2010 12:28 am
Just curious,where are your resevoirs leaking from?
How are they attached to the master cylinders?
PostPosted: Mon Jan 11, 2010 9:10 am
leaking around the push rod
PostPosted: Mon Jan 11, 2010 10:30 am
Oh, master cylinder is whats leaking, get rebuild kits.
PostPosted: Mon Jan 11, 2010 5:33 pm
Ok I'll just look online, lol, this isn't working :?
