| Cross drilled rotors???????? http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=8125 |
| Author: | Firebug [ Sun Nov 22, 2009 9:56 pm ] |
| Post subject: | Cross drilled rotors???????? |
I am upgrading my rear brakes and have seen some rotors cross drilled,,Who has done this? How did you get the pattern,,,what size holes? Are they braking better,,or are they cracking? |
| Author: | Maddog [ Sun Nov 22, 2009 11:33 pm ] |
| Post subject: | Re: Cross drilled rotors???????? |
I did mine years ago, just used a magic marker to lay out the lines in a swirl pattern for 3 rows of holes. It helped some,but what really helped was mounting calipers off a 87 suby front that had emergency brakes, and pads 4" long. I like having my emergency brake, makes me worry less. |
| Author: | MickeyMouse [ Mon Nov 23, 2009 2:52 pm ] |
Just a thought, would the holes in the disks capture and hold mud.. Causing more wear on the pads.. |
| Author: | tw9294 [ Mon Nov 23, 2009 3:00 pm ] |
You want directional slots. Holes just cut wieght and look cool. |
| Author: | PhillipM [ Sun Mar 21, 2010 5:48 pm ] |
Holes do indeed just trap mud, you want these: ![]() We've used 'em over here for years, scrapes all the mud and water off the pads + discs without the risc of cracking under heavy braking. |
