| *?Brake lines for the front?* http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=8106 |
| Author: | DUBclub [ Thu Nov 19, 2009 1:19 pm ] |
| Post subject: | *?Brake lines for the front?* |
ok so i have a 6" wider worrior beam, 4x2 arms, and 3" raised combo spindles, and 2 piston gear-one disc brakes my question is how should i run the brake lines so they do not bind? or where whould i run them? and how have you ran your lines? if any of you could post some pictures that would help...thanks guys |
| Author: | MadMike [ Thu Nov 19, 2009 10:07 pm ] |
| Post subject: | Re: *?Brake lines for the front?* |
My brake lines start at a staging brake into a "T", 2 lines run up the center of the car to the steering rack. At the rack they run down the drag links (tie rod sleeves) to the calipers. I have a coulpe of hose clamps that lightly hold them in place. Never had them get caught on anything. |
| Author: | DUBclub [ Fri Nov 20, 2009 12:27 am ] |
thanks man...yeah i figure i need to start looking into it and reading up on what people have done before i try to start making my setup...kinda like the "measure twice cut once" |
| Author: | MadMike [ Fri Nov 20, 2009 9:30 pm ] |
Ya mean not cut it twice and it's still too short. |
| Author: | DUBclub [ Sat Nov 21, 2009 9:18 am ] |
yeah so far the only thing that i have done wrong is that i ordered the same size rim fro the front as the rear and i for got to add in the extra width of the beam....oops well thats fixed now so that is why im now taking extra time to make shure not to make a mistake on another part that im trying to fit... thanks again |
