It is currently Sun May 03, 2026 10:59 pm
PostPosted: Thu Nov 19, 2009 1:19 pm
ok so i have a 6" wider worrior beam, 4x2 arms, and 3" raised combo spindles, and 2 piston gear-one disc brakes
my question is how should i run the brake lines so they do not bind?
or
where whould i run them?
and
how have you ran your lines?
if any of you could post some pictures that would help...thanks guys
PostPosted: Thu Nov 19, 2009 10:07 pm
My brake lines start at a staging brake into a "T", 2 lines run up the center of the car to the steering rack. At the rack they run down the drag links (tie rod sleeves) to the calipers. I have a coulpe of hose clamps that lightly hold them in place. Never had them get caught on anything.
PostPosted: Fri Nov 20, 2009 12:27 am
thanks man...yeah i figure i need to start looking into it and reading up on what people have done before i try to start making my setup...kinda like the "measure twice cut once"
PostPosted: Fri Nov 20, 2009 9:30 pm
Ya mean not cut it twice and it's still too short.
PostPosted: Sat Nov 21, 2009 9:18 am
yeah so far the only thing that i have done wrong is that i ordered the same size rim fro the front as the rear and i for got to add in the extra width of the beam....oops well thats fixed now so that is why im now taking extra time to make shure not to make a mistake on another part that im trying to fit...
thanks again :!:
