It is currently Mon May 04, 2026 4:25 pm
 Post subject: disc brakes
PostPosted: Thu Mar 19, 2009 9:32 pm
I just bought a new buggy and it had a bus torsion in it. It had disc brakes on it but they were junked. so i bought some new ones to put on it the problem is the brackets have to be welded on to the hub part of the torsion and it is cast and i cant seem to get my welds to hold. have any of you ever had this problem and do any of you all know a way maybe i could just bolt them on thanks .
 Post subject: Re: disc brakes
PostPosted: Fri Mar 20, 2009 9:04 pm
go to the speed shop in hariman and larry can weld them on for you
PostPosted: Fri Mar 20, 2009 10:14 pm
A) If they are cast Iron you need to use rod designed forit and B) you need to pre heat the castings
