| CNC Turning Brakes http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=4985 |
| Author: | MickeyMouse [ Thu Oct 30, 2008 9:05 pm ] |
| Post subject: | CNC Turning Brakes |
I am installing Turning Brakes and I do not have enough room for the handle. Has anyone ever shortened the handle. If so, did you lose any braking? was he handle hard to push down or pull up? I am using a single handle brake and I have disc brakes on the back. Thanks Dan |
| Author: | countri boy 84 [ Thu Oct 30, 2008 9:23 pm ] |
| Post subject: | Re: CNC Turning Brakes |
I am running dual handle and have cut them down 4 inches to match shifter height to make them easier to grab in a O-SHIT situation. I haven't noticed a difference enough to not do it again but I'm currently runnin drums. Hope it helps. |
| Author: | tanner2803 [ Thu Oct 30, 2008 9:27 pm ] |
hey i cut the daylights out of mine b.c i have no room for them and they are just as easy to use |
| Author: | tanner2803 [ Thu Oct 30, 2008 9:47 pm ] |
heres some pictures i think i cut like 8 inchs or so out they look crapy but i had to hold them where i wanted and weld at the same time bymyself so yea..... lol but as shortness they are just as easy i think here u go ![]() ![]() and heres my new staging brake its taller but might give some ideas
| Author: | chris38375 [ Thu Oct 30, 2008 10:18 pm ] |
if u got big bore,3/4 pistons in ur cutting brakes u should be good no matter how short u cut them |
| Author: | MickeyMouse [ Fri Oct 31, 2008 10:14 pm ] |
Thanks fellas. I am going to mount the brakes this weekend and cut the handles down. I will let you know what happens.. |
