It is currently Sun May 03, 2026 8:28 pm
 Post subject: Goin Disc
PostPosted: Wed Oct 22, 2008 10:55 pm
I know its probably here but what is the best and cheapest way to stop don't have much of a budget this close to X-MAS so any input would be nice.
WHEN IN DOUBT DRINK ANOTHER BEER!!!!!!!!!!
 Post subject: Re: Goin Disc
PostPosted: Wed Oct 22, 2008 11:06 pm
Disc are the best,,once you get them on they last a long time. Drums wear out fast and don't stop as well. I used Corolla calipers with Datsun 280z rotors fitted over VW 4 lug hubs cut down to fit in the rotors. I' m sure there are many ways of doing disc. good luck
PostPosted: Thu Oct 23, 2008 12:57 pm
Datsun discs like Firebug is describing:
Early 80's Nissan sentra front calipers:
I've used this setup for several years and it works very well, is cheap, and you can buy parts at any part store in the country. :)
Aut Viam Invenium Aut Faciam!
PostPosted: Thu Oct 23, 2008 4:03 pm
is that the stub from the datsun?
PostPosted: Thu Oct 23, 2008 7:45 pm
It is the end of the stub from a datsun....... I machined it down and welded it to a vw stub with the flange gone.
Tranny side
axles
"zig-zag" cased 3.88 tranny
The whole setup is pretty much bulletproof if you run stock trailing arms. :mrgreen:
Sorry for the hijack...
PostPosted: Thu Oct 23, 2008 7:52 pm
Cool setup never seen that before.
PostPosted: Thu Oct 23, 2008 8:49 pm
What is that tranny :?:
PostPosted: Thu Oct 23, 2008 9:06 pm
Its a "zig-zag" gah I thought eveyone knew that. LOL . How are yall machining the drum down to fit the rotor in a brake lathe or what.
PostPosted: Thu Oct 23, 2008 9:38 pm
Yea,,I had a buddy do it on a brake lathe.. then I put studs in it .I redrilled the Z rotors on my drill press so the 4 lug vw studs go through. 8)
PostPosted: Thu Oct 23, 2008 9:49 pm
Any body have a set of these shafts forsale? I have been looking for a set.
PostPosted: Fri Oct 24, 2008 10:15 am
They came in late model bugs. 78-79 I think.... The center rib moves over the point where earlier cases break and strengthens them a lot. The rhino cases just add more beef to the center which doesn't stop the crack from forming over close to the side plate. The ring gear tries to "climb" the pinion gear and it causes the case to twist on that side.
Its pretty old school. It works good if you use stock length trailing arms. You can put all the power thru them you want without any trouble from them. 2X3 or 3X3 arms will kill them within a day though. :mrgreen:
Most of the time a junk yard will have an old datsun laying around waiting for the crusher. Parts aren't just flying off the shelf for them so you can get them pretty cheap. Good thing is, once you build them, the only thing that you ever would possibly need to change is the U-joints. Either go to Nissan and get the originals to put back or get Spicers. The original Nissan are better than anything you can buy though.
PostPosted: Mon Oct 27, 2008 12:59 pm
Has anyone ever used these kits not a bad price I dont think
http://www.thesamba.com/vw/classifieds/ ... ?id=637249
PostPosted: Tue Oct 28, 2008 10:12 am
The splines in the hubs of those are WEAK!!! I've seen several sets of those that were stripped out.
PostPosted: Tue Oct 28, 2008 6:42 pm
thats not a bad start u could up grade on roters later on.when youv got some extra cash.
PostPosted: Thu Nov 06, 2008 3:57 am
I used front caliper and rotors off a datsun 280x for my rear disc conversion. I took the 4 lug brake drums, cut the "drum" part off so it was a hub and I still got to use the good german steel. I then took a skim cut off the back of the hub so the rotors would have a flat surface to bolt to. than drilled and tapped accordingly. So in the end the rotors are bolted to the back of the hub and the wheel is on the front of the hub. If anyone cares, let me know and I'll take pics.
PostPosted: Thu Nov 06, 2008 8:38 am
Please do take pics,,that sounds neat 8)
PostPosted: Thu Nov 06, 2008 11:42 am
That is the same setup I have but I used Sentra calipers instead in order to be able to get better pads without having to order them. Most parts stores keep the good sentra pads in stock. :)
PostPosted: Mon Nov 10, 2008 1:17 am
I was gonna take the wheel off and take better pics but it's in the 30's outside, and I hate the cold. So here's the pics I got. Like I said I turned the drum down and than drilled and tapped the "hub" so the datsun rotor would bolt to it. I used the datsun 280z calipers because the pads are huge, for the size of the caliper and rotor. I was gonna use mid 90's grand prix calipers because they are dual piston but the pads are really small.
PostPosted: Thu Nov 27, 2008 11:08 pm
ridge runner and suby steve made a set and gave to me they machined down the vw drum for an adapter and used 94 jeep cherokee rotors and drilled them and 2003 kia sonata calipers i think
