It is currently Mon May 04, 2026 7:17 am
 Post subject: what is it ?
PostPosted: Fri Aug 08, 2008 6:19 pm
hello, just to start off and say this is a very good site full of information and helpful fellow buggy builders?
I just bought a rolling frame that had been put to together from a kit, don"t know what kind but you can tell it was not welded at a factory level, but any how it has disc brakes on the rear but one of the calipers is frozen up. Can someone tell me what kind of caliper I have by the numbers cast into the housing on the caliper?
Heres what is cast into it: VWII 100521 KH 05.
Any help you will be great cause I don"t have a clue what it is, or How to replace it with one from a auto parts house.
 Post subject: Re: what is it ?
PostPosted: Sat Aug 09, 2008 11:30 pm
most of the calipers we use ase are off of the front of a '68 sqareback. maybe this will help.
Woody
PostPosted: Sun Aug 10, 2008 11:42 am
Do a search on Varga calipers. I'm looking to see if I have any pict. to post.
PostPosted: Sun Aug 10, 2008 11:56 am
Does it look like this?
If it does it is a Varga.
PostPosted: Sun Aug 10, 2008 6:25 pm
no it is a lot larger, I will try to get a pic, later this evening?
PostPosted: Sun Aug 10, 2008 6:29 pm
If its bigger, its probly off a bus front end. A pic is the only way to tell
PostPosted: Mon Aug 11, 2008 8:35 pm
Stopped by oreillys today and they crossed over the casting numbers and had a match, but had to order, not in stock, but I forgot what it was support to fit, I will see tomorrow.
thanks for the support.
