 Post subject: AN fitting Quetions
PostPosted: Sun Aug 03, 2008 12:06 am
Hello everyone,
Im trying to figure out the fittings i need for my brake lines. I bought all my hose and they all end with female -3 ends. So my question is what size hole is coming out of the CNC brake pedal master cylinder also the same with the turning brake and clutch. The fittings i need are double male sided with obviously -3 on one side and a american fitting on the other. Does anyone no these fittings.. Also i have to do the same thing on my front and rear calipers inlets My front breaks are Pro-am and my rear is Gear-one does anyone know what size these holes are??
CNC = ? to -3
Gear-One calipers= ? to -3
Pro-am caliper= ? to -3
Hopefully this makes sense and someone had the same problem and can just tell me what size holes are in all these products..
Thanks always
Nick
 Post subject: Re: AN fitting Quetions
PostPosted: Sun Aug 03, 2008 1:53 pm
The cnc stuff is 1/8th inch npt thread not sure on rest
PostPosted: Sun Aug 03, 2008 8:26 pm
Piping brakes was a big learning curve for me. I had part metric fittings and part npt fittings. Several trips to autozone. :( and alot of head scratchin. Good Luck, I'm sure you'll get it figured out.
Bryan
PostPosted: Sun Aug 03, 2008 10:09 pm
Hey Guys,
Thanks forr the help looks like everything i have is 1/8 NPT and everything i bought is AN-3. But i got it all figured out. Im guessing the hole on my slave cylinder is 1/8NPT aswell..
PostPosted: Mon Aug 04, 2008 12:47 pm
All of the aftermarket stuff is 1/8" NPT that I know of.
PostPosted: Mon Aug 04, 2008 8:57 pm
All my aftermarket stuff is. thanks for the help guys..
