It is currently Sun May 03, 2026 10:59 pm
 Post subject: Best master cylinders
PostPosted: Mon Sep 15, 2008 10:11 pm
Need some input from ya'll, I don't know wether to go with the CNC pedals and master cylinders or the Wilwood set up. When it comes to brakes I don't mind spending a little extra for top quallity!! Going is important but stopping is real important!! Or if there are any better options other than the ones I mentioned let me know!
PostPosted: Fri Sep 19, 2008 9:37 pm
I use wilwood master cylinders. the rear one is a square one and the front one is the round one. I swear they look identical to CNC and jammer's. what i did, is i went to summit, bought the wilwood cause it was a better price.
PostPosted: Sat Sep 20, 2008 5:45 pm
I've looked at both since I first posted this, and they look to be about the same? probably not much difference in them. Think i will go with the Willwood.
PostPosted: Mon Sep 22, 2008 12:50 pm
Be sure of the availability of rebuild kits before you choose.
Hopefully you will never need to but just in case............... 8)
PostPosted: Tue Sep 23, 2008 2:35 pm
Good point!!
