It is currently Mon May 04, 2026 6:29 pm
 Post subject: cutter brake
PostPosted: Mon Apr 14, 2008 8:20 pm
i had to repalce rear brake line today. now i can't get my cutter to hold. the top one holds a little but the bottom one is not working at all. i went through 2 quarts of brake fluid trying to bleed them off . but i still have nothing. any help would be greatly appricated
new to buggy world and not afraid to take advice
yellowcreek campground lot#5
PostPosted: Mon Apr 14, 2008 8:21 pm
forgot it is a single handle cutter
PostPosted: Mon Apr 14, 2008 10:56 pm
Did you bleed the cutting brake itself. You may need to take the caliper off and put a piece of wood or steel between the pads and then go through the bleeding process again except hold the caliper so its at the highest point of your brake system. If all else fails try a pressure bleeder that you either pump or connect an air hose to.
PostPosted: Wed Apr 16, 2008 8:06 pm
i tried all those things going to buy a rebuild kit tomorrow
PostPosted: Sat Apr 26, 2008 9:57 pm
When you bleed the brakes you need to make sure the bleeder your opening is the highest point on the caliper most of the time you need to unbolt it.
aaron
