It is currently Mon May 04, 2026 1:55 am
 Post subject: turnbrake
PostPosted: Sat Oct 06, 2007 8:44 pm
help my left turning brake does not work right is ok took it out brakes work great it is a jamar are they just junk or am i doing something wrong it was new when i put it in neve has work right
drive it like you know how too fix it
PostPosted: Sun Nov 04, 2007 11:23 pm
Take it apart and see if the seal is ripped we had a couple that were like that brand new,if so you need a wheel cylinder hone and a rebuild kit,did you bleed the turning brake there is a allen screw somewhere that you can bleed it with.When you bleed you brakes make sure the bleeder on the caliper is the highest part of the caliper you will need to unbolt it and put something between the pads so you can bleed it.hope this helps
aaron
