 Post subject: mounting calibers
PostPosted: Thu Apr 14, 2016 2:56 pm
Got a set of nissian sentra calibers for the buggy and fixing to make mounts for them.How do I figure out exactly were the caliber should be. Should they be pushed pretty much against the out side pad? Thanks.
 Post subject: Re: mounting calibers
PostPosted: Fri Apr 15, 2016 12:04 am
Place them on rotors as far toward the center as possible without passing the edge of rotor. Apply air to collapse caliper. This will reveal where to mount your bracket.
PostPosted: Fri Apr 15, 2016 8:21 am
Thanks. Just pull bleeder out and shoot some air in there? Ill give that a shot.
PostPosted: Fri Apr 15, 2016 5:49 pm
Yes, that will work. It's best if you can leave air hose on. So it doesn't move while worki,g on it.
