It is currently Sun May 03, 2026 12:53 pm
 Post subject: Heim joint tie rods
PostPosted: Tue Feb 25, 2014 1:30 pm
I'm looking to swap out my worn out tie rod ends with Heim joints. What size is everyone running? I've found a few kits that are built to length that'll cost not much more than replacing all my tie rods. Thanks for the help in advance.
 Post subject: Re: Heim joint tie rods
PostPosted: Tue Feb 25, 2014 1:36 pm
5/8" and 3/4"
PostPosted: Tue Feb 25, 2014 5:59 pm
I have had good luck with 5/8 heim and miss alignment spacers that step the bolts down to 7/16. I bought some air craft hex aluminum from mc master Carr and cut and drilled and taped them myself. I used all right hand thread so I only need to carry one spare. But I had that set up for the last five years and never needed it.
PostPosted: Tue Feb 25, 2014 8:21 pm
I'm running 5/8"
PostPosted: Tue Feb 25, 2014 10:51 pm
I too run 5/8 with 1/2 miss alignment
PostPosted: Tue Mar 18, 2014 5:37 pm
Speedway motors. You can't hardly beat there prices.
PostPosted: Thu Mar 20, 2014 10:47 am
Yeah that's where I was looking at. They have the whole rod and end set up in many different lengths.
PostPosted: Thu Mar 20, 2014 10:48 am
X2. That's were my setup came from.
PostPosted: Thu Mar 20, 2014 11:19 am
18in long alum hex with 3/4 himes with shims to use a 5/8 bolt
PostPosted: Thu Mar 20, 2014 5:03 pm
Where did u get the aluminum hex
PostPosted: Thu Mar 20, 2014 5:55 pm
Race shop next to my house. They use them for 4link bars on dirt cars so speedway prolly has them
PostPosted: Sun Jul 27, 2014 4:51 pm
What size tires are you guys running with the 5/8 hiem joints
PostPosted: Sun Jul 27, 2014 6:39 pm
29x8.5 swampers
PostPosted: Sun Jul 27, 2014 7:46 pm
We run 3/4 heims with mis alignment adspters to 1/2 bolt. .they tough ass hell!!!!
PostPosted: Wed Jul 30, 2014 9:00 am
Nribuggys where did you get the shimes. I had to make my 5/8 to 1/2
PostPosted: Wed Jul 30, 2014 9:04 am
PostPosted: Wed Jul 30, 2014 9:05 am
PostPosted: Wed Jul 30, 2014 9:59 am
Same here.
PostPosted: Wed Jul 30, 2014 12:33 pm
I think summit has the 5/8 to 1/2 and I run 3/4 to 1/2 works great. I believe the proper name is high misalignment spacers. Gotta have two per heim. The reason I didn't go with the 5/8 to 1/2 is there isn't a lot of material in the spacer wall going from 5/8 to 1/2 so the spacers are kinda weak and could collapse if over tightened
PostPosted: Wed Jul 30, 2014 1:14 pm
They sell them at the race shop by my house. I'm think they come from speedway. He gets a lot of parts from them
PostPosted: Wed Jul 30, 2014 4:15 pm
I just went with the same set up as nribuggy found a race shop by my house
