It is currently Tue May 05, 2026 2:52 am
 Post subject: DIY raised spindles
PostPosted: Tue Jul 23, 2013 9:30 pm
I am actually messing with raising the front of my buggy right now. I went to a buggy swap this past weekend and found a Ghia front disk brake kit with lowered spindles for $75. The good thing about lowered spindles is that you just need to use a thin disk grinder to cut through the welding beads. About 20 minutes later and some beating with a hammer and a chisel and they came apart. I am having issues removing the lower ball joint but as soon as I do I will have 1 side done. The calipers looks fine but at $80 for a loaded pair its not that bad. I will post some pics later during the week.
