It is currently Tue May 05, 2026 12:01 am
 Post subject: what studs??
PostPosted: Wed May 29, 2013 2:30 pm
I recently went and added front brakes on my buggy and now I'm wanting too do away with the standard screw in studs and go with a longer press in. Which studs do I need? I have to go through the rotor, 5/8 spacer, and a 3/8 adapter.
 Post subject: Re: what studs??
PostPosted: Wed May 29, 2013 3:59 pm
Sounds like you know the dimensions add them up and add the thickness of the lug nut and add about 3/8 so you have three treads beyond the lug nut. Unless you intend to use an acorn style lug nut.
The size diameter wise depends on the size hole you intend drill
PostPosted: Wed May 29, 2013 6:01 pm
this might help...http://www.speedwaymotors.com/search.ht ... =lug+studs
