what studs??
http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=15473
Author:  OrangeCrush [ Wed May 29, 2013 2:30 pm ]
Post subject:  what studs??
I recently went and added front brakes on my buggy and now I'm wanting too do away with the standard screw in studs and go with a longer press in. Which studs do I need? I have to go through the rotor, 5/8 spacer, and a 3/8 adapter.
Author:  Red Barron [ Wed May 29, 2013 3:59 pm ]
Post subject:  Re: what studs??
Sounds like you know the dimensions add them up and add the thickness of the lug nut and add about 3/8 so you have three treads beyond the lug nut. Unless you intend to use an acorn style lug nut.
The size diameter wise depends on the size hole you intend drill
Author:  Russ-the-Buss [ Wed May 29, 2013 6:01 pm ]
this might help...http://www.speedwaymotors.com/search.ht ... =lug+studs
