 Post subject: weld on caliper mounts
PostPosted: Tue May 14, 2013 12:41 am
i have changed to a set of 3x3 boxed trailing arms and my caliper mounts will no longer bolt up to the axle flange.so i ordered some weld on caliper mounts.what do i do about shimming the bearing cap the thickness of the bolt on mount?should i just cut the mount down to just the flat part or what?
PostPosted: Tue May 14, 2013 8:02 am
Yep, otherwise you will snap the lugs off the cap when you tighten the bolts.
PostPosted: Wed May 22, 2013 10:40 pm
anybody know of a good exploded view of the rear hub assembly.i ordered new seals and wanna make sure it all goes back together right
