It is currently Mon May 04, 2026 5:20 pm
 Post subject: name this caliper please
PostPosted: Mon May 13, 2013 9:53 pm
i have a brake hanging up. stock pedals
cnc cutters,
brakes hang up until you crack the line loose or just wait and it stars to loosen after 5 or 10 minutes
I am going to replace master cyl but I already had a bleeder break and a line is dry rotted so I need to figure out what these are.
thanks for help
also what stock master cyl has one top port for a reservoir? thanks guys
PostPosted: Mon May 13, 2013 9:57 pm
maybe this picture will work
PostPosted: Mon May 13, 2013 10:12 pm
Sounds like a caliper piston hanging from some corrosion between the piston and bore
PostPosted: Mon May 13, 2013 10:27 pm
It is likely just the dry rotted rubber line that is causing the problem. When they get old they collapse and restrict the flow of fluid. The reason your brake hangs is because it take a few minutes for the fluid to release the brakes due to the bad rubber hose. Again, this is the same reason that craking the bleader/hose releives the pressure.
PostPosted: Mon May 13, 2013 10:45 pm
X2
PostPosted: Mon May 13, 2013 10:56 pm
Thanks. I figured new hoses and calipers, I just have to figure out what caliper I have. Looking at AutoZone website they aren't the Nissan Sentra caliper that is popular. Might have to go to a parts store and do some searching.
PostPosted: Mon May 13, 2013 11:35 pm
Post a larger pic if you can.
PostPosted: Tue May 14, 2013 12:58 am
I tried but it said it was to many pixels. So I shrunk it. I will try again. I work nights so I can text it to anyone or e mail it. Thanks again for your time. 765 603 8048 just let me know and I can send it and I do appreciate it
PostPosted: Tue May 14, 2013 3:59 am
Looks like maybe a 84 dodge omni. Will find out later
