PostPosted: Sat Mar 16, 2013 3:09 pm
Will a set of 1993 Ford Mustang calipers work with Porsche 914 rotors? If not what would work that are fairly cheap or from the junkyard. Also i have stock trailing arms. Will the disc conversion work with stock vw rear suspension?
PostPosted: Sat Mar 16, 2013 5:54 pm
Nissan sentra calipers are cheap and work good. Ford mustangs probably would to but aren't they on a vented rotor? Might have to use a spacer.
PostPosted: Sun Mar 17, 2013 7:47 pm
About how much are a set of sentra calipers. I bought a buggy a few hours ago that had benn wrecked that had what looked to be porsche 914 rotors but no idea what calipers
PostPosted: Mon Mar 18, 2013 12:25 am
sentra calipers are $43 a piece including core charge plus $15 for pads . im pretty sure this is what im gonna go with. its about the cheapest ive found to fit the non vented rotor. if you order online at advance and enter the promo code MC18 you can get it all shipped to your door for $89. I think that promo ends like march 23
PostPosted: Mon Mar 18, 2013 1:27 am
What about calipers off a 87 grand am 4 cyl I have seen them without vented rotors and are 19.99 plus 5 core at advance auto I have a set here I'm gonna try out the ones i have are aluminum and lightweight I think they make a cast caliper also
PostPosted: Mon Mar 18, 2013 1:45 am
are you talking about the rears or fronts? the sentra calipers are for the front so they should have a larger piston(more stoping power)
PostPosted: Mon Mar 18, 2013 2:15 am
The front this iron duke setup I got here on a buggy is the whole motor trans kframe and struts out of a 86 87 grand am mounted in a buggy and it has non vented rotors with aluminum calipers Image
Don't hold me to this I'm gonna research it tomorrow to see if I'm correct or wrong :mrgreen:
PostPosted: Mon Mar 18, 2013 6:09 pm
I called advance auto and they told me i need a specific date of manufacture? I asked for a set of 86 Sentra calipers and they showed two different sets. So what do i tell them next time i call?
PostPosted: Mon Mar 18, 2013 6:44 pm
looking it up online im getting the same partnumber for 85 86 87 so im not sure but heres the part numbers.
slc8664 right caliper
slc 8665 left caliper
emkd 275 pads
PostPosted: Tue Mar 19, 2013 12:07 am
davidk thats not a grand am thats a fiero. it does however have grand am struts on it.
PostPosted: Tue Mar 19, 2013 12:10 am
u might be right there guy told me grand am i never bothered to check thanks
PostPosted: Tue Mar 19, 2013 8:32 pm
emkd 275 pads
With these calipers how would i mount them? What is the best methodto do so and it be straight? Can someone give me ant advice
PostPosted: Tue Mar 19, 2013 8:43 pm
I mounted my rotor then Mocked up the caliper and bled the system to clamp it down on the rotor used some card board for a spacer between the rotor and caliper then fabed a bracket an welded it on.
PostPosted: Tue Mar 19, 2013 11:02 pm
Is this for the type of caliper that slides? Because the set that i pulled off the spare buggy have a piston on each side of the rotor.
PostPosted: Tue Mar 19, 2013 11:50 pm
They are for GM metric floating calipers but brackets are fabed for the type you are mounting
PostPosted: Wed Mar 20, 2013 12:12 am
You can also run air into the calipers, center them up and get them where you want then turn the pressure up and weld. I just took a brake line with one end cut off, slipped a piece of fish tank hose over it then over my air nozzle to get air into the caliper.
PostPosted: Wed Mar 20, 2013 10:00 pm
emkd 275 pads
Well i just ordered these and pads. What is the smallest wheel these will clear i have stock length irs suspension. After i mounted the cut down drum and set the rotor on and put my tire up to it, it looks like i will have a clearance issue but i wont know for sure till friday afternoon. Can anybody with this setup tell me what size wheel and tire you are running. The buggy is at my buddys house so i cant go look to see what size ive got ill give him a call shortly. Thanks for all the advice.
