 Post subject: Nissan sentra brakes
PostPosted: Mon Jan 28, 2013 1:04 pm
Hello. I'm running 1989 Nissan sentra calipers with redrilled 280 z rotors and a bug master cylinder. No cutters yet. Everything is new now. I have about a 1/8 inch free play at the petal before it hits the master cylinder. I sanded down the pads because it was a right fit installing the calipers .. There's about a 1/16 inch gap between the pads and rotor after I installed them. Everything moves freely and in good working order. I'm pretty sure they are fully bleed. They are dragging pretty badly. they are both very slow to release. Anyone ever have this issue ?
 Post subject: Re: Nissan sentra brakes
PostPosted: Mon Jan 28, 2013 1:17 pm
I havent. are the calipers nice and square?
PostPosted: Mon Jan 28, 2013 1:33 pm
Are ur rotors new?
if not they could be warped
PostPosted: Mon Jan 28, 2013 3:53 pm
Crack a bleeder and see if it releases quicker. If so its your hoses
PostPosted: Mon Jan 28, 2013 7:54 pm
Are the calipers floating on the slides ? I have seen people install calipers where they didn't float back and forth. The mounting bracket will bend or the rotor will eventually break when it is bent by the non floating caliper.
Huey
PostPosted: Sat Feb 02, 2013 1:48 am
Thanks fellas for all the info .. It has new rotors , calipers ,hard lines , vw soft lines , pads , master cylinder . The calipers are installed square , true to the rotor and the pins slide good. I used a adapter from factory vw rubber lines directly to the stock sentra rubber line. The are old lines .. I will check them out. Something I noticed today is the brake petal will be extremely hard a few pushes then get kinda soft ( normal ) feeling a few then back hard .. It doesn't travel any different tho .. Here's the weird part my brake light switch is installed in the master cylinder .. They only light up when the petal it's soft feeling. I might have a bad new master cylinder .. It's a name brand from Roy Rodgers for a bug . What do y'all think ? Need any pictures of anything ? Let me know. Thanks greatly you guys !!
P.s. they don't stop the car very well at all never really have ! Won't lock up a 31 inch co op if you stand on the petal !
PostPosted: Sat Feb 02, 2013 11:24 am
lights only when it feels normal? sounds like somethings binding possibly the master. post a pic of your pedal/master assembly.
PostPosted: Sat Feb 02, 2013 11:26 am
do the brake lights stay on when the brakes drag?
PostPosted: Sat Feb 02, 2013 11:41 pm
I will get you a picture in the morning. It's just you're normal stock petal assembly and box. I braced it up some. Nothing seams to be binding up on it. I'm thinking its this new master cylinder. The brake lights do not stay lit when they drag . It's like they are slow to release .. You can tell they are engaged for about ten feet of driving after you hit them. I almost tore the hole buggy apart tonight tho. Brakes are still fully assembled. Thank you for the help and ideas man
PostPosted: Sun Feb 03, 2013 12:11 am
if the lights are not staying on i would think its not the master binding.I would lean toward the hoses. your pistons in the ca;ipers arent coming out to far are they? post a pic of the caliper showing the piston and how far out it goes when braking. to narrow it down to which brake is dragging take a good ride using the brake frequently. as soon as you get out feel the heat from the wheels. if one seems abnormaly hot thats your culprit.
PostPosted: Sun Feb 03, 2013 1:25 am
probably is the hoses not letting the pressure back out. replace them with sainless braided ones and be done with it!
PostPosted: Sun Feb 03, 2013 9:00 am
Thank you all for the comments and suggestions. I will replace the lines when i reassemble the buggy I got some pictures
Think this is my issue ! I didn't install it all bent up like that !! :evil: :twisted:
PostPosted: Sun Feb 03, 2013 10:06 am
yeah that bend looks pretty nasty. i would definately replace that even if it isnt the problem.
PostPosted: Sun Feb 03, 2013 10:27 am
I would fix the brake lines first but still verify the calipers are true on the rotors .
Easiest way I found is to take a blow gun or some air tools have a valve for adjusting air flow . The blow gun is what I used and you can thread a brake fitting in the end. That is threaded . Attach other end to caliper hose and then you can send air pressure to caliper and ck how they are working . On mine when you release the air the caliper the wheel turn completely free .
PostPosted: Thu Feb 07, 2013 1:19 pm
The bent line still flowed really well .. It's all disassembled and I inspected everything real well the calipers are square and are releasing correctly. I did notice when I drained the system I had pressure on both bleeders. I got a good squirt when I opened them .. No petal pressure. I'm going to replace the rubber lines and the Ben metal one when I reassemble it .. The master cylinder is sticking now it's empty .. Think I'm replaceing it too .. Should I go back with a bug one ore a bus one ? Like I said these brakes never really worked like y'all described ... I greatly appreciate all the information and help so far
PostPosted: Fri Feb 08, 2013 10:16 pm
if you can aford it go on and get you all new hydrolic pedal setup and if you can really afford it put a willwood breat master cylender on it
PostPosted: Sat Feb 09, 2013 3:09 pm
if you had pressure on both bleeders your hoses are bad.
PostPosted: Sat Feb 09, 2013 3:36 pm
x2 Happens from calipers hanging and tearing the inner layer creating a one way check. Also reasonable advice to eliminate rubber brake hoses because the hyd. pressure expands the hose making more pedal travel. The old VW single master cyl. is made for 4 wheel drums and the larger bore makes it hard to create the pressure to lock up the wheels on pavement. JMHO
PostPosted: Tue Feb 12, 2013 11:28 am
I wish a hydraulic petal set up was in my budget !! Ballin on a budget here .. I'm going to replace the rubber lines with ss lines if I can find em reasonably priced.
So is there a smaller bore master cylinder I can use. And keep using my stock petal assembly that will work better with my disk ? Because they aren't worth a damn right now !!! I have a few other brand new bug master cylinders on the shelf . Thanks for the help fellas
PostPosted: Tue Feb 12, 2013 1:22 pm
Speedway Motors is one place to look for single master cylinders.
PostPosted: Thu Feb 14, 2013 7:55 pm
What's size should I look for ?
