rebuild kit for bugpack
http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=14410
Author:  alwystrninwrnchs [ Thu Nov 29, 2012 4:03 pm ]
Post subject:  rebuild kit for bugpack
Where can I get a rebuild kit for a bugpack single arm cutter?
Ive looked everywhere it seems
Author:  fortydegnorth [ Thu Nov 29, 2012 5:14 pm ]
Post subject:  Re: rebuild kit for bugpack
Might compare it to a Jamar. It seems like I read somewhere that they were basically the same. I'm pretty sure the Bugpack kits are discontinued now.
It might be easier to just buy a new cutting brake. They aren't terribly expensive and then you will easily find parts for it.
Author:  Red Barron [ Thu Nov 29, 2012 7:06 pm ]
Best of luck and check the bore if it is pitted at all junk it and elect for a cnc.
Author:  alwystrninwrnchs [ Sat Dec 01, 2012 1:59 pm ]
haha, Yea im gonna try to find a cnc cutter but I doubt i can afford one.
Author:  Red Barron [ Sat Dec 01, 2012 3:30 pm ]
It should be less than $120.00. I think I paid $95.00 for mine about 4 years ago.
Author:  bige70chevy [ Sat Dec 01, 2012 4:46 pm ]
try southern buggies or drews off road
Author:  kvw [ Sat Dec 01, 2012 10:00 pm ]
Have you taken it apart yet? If it just needs a new cup seal you can get one at NAPA, should be the same seal used in wheel cylinders.
Good Luck
Kenric
Author:  alwystrninwrnchs [ Sat Dec 15, 2012 11:49 pm ]
I took it apart and the first o ring was wore flat so I tried to find one and couldnt so I took a bit larger seal and cut it at a angle and glued it together seems to kinda work it doesnt leak out of the front anymore I just have to bleed it out I still want a different set.
