It is currently Mon May 04, 2026 2:32 am
 Post subject: Brake ???
PostPosted: Sat Feb 25, 2012 2:55 pm
Can anyone tell me if an aftermarket disc brake setup of a swingaxle buggy will work on my IRS? Rotors and calipers look the same but I'm not sure about bracket and splines
Thanks
 Post subject: Re: Brake ???
PostPosted: Sat Feb 25, 2012 4:24 pm
Yes. This was several years ago, if my memory serves me, A buddy converted his Swing axle set up to IRS using the same kit. I do believe he had to use a spacer/washers to put the axle nut on because of having short spined swing axle.
