| Brakes won't release http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=12925 |
| Author: | bigDsmith [ Mon Jan 09, 2012 8:48 pm ] |
| Post subject: | Brakes won't release |
System is bus master cylinder with rear drums only (for now). Also running dual handle CNC Cutting brakes. Here is the problem: after depressing the foot brakes the brakes don't release. I have to crack a bleeder to release the brakes. The cutting brakes work perfect. Only when I press the foot brakes the lock up happens. |
| Author: | kevin f [ Mon Jan 09, 2012 9:12 pm ] |
| Post subject: | Re: Brakes won't release |
Check and make sure you have slack in the linkage on the cutters. i ran into that same problem a few weeks ago on mexican freds buggy. I had to shorten the adjustments in the cutter and it worked fine. |
| Author: | gasman [ Mon Jan 09, 2012 10:13 pm ] |
Do you have solid lines to the cutters,could have a collapsed line if it's rubber or braided.chad |
| Author: | giveitagallon [ Mon Jan 09, 2012 10:19 pm ] |
You dont have one of them cheap brake locks do you ? |
| Author: | bigDsmith [ Mon Jan 09, 2012 10:35 pm ] |
No brake locks and solid lines to cutters. Everything is new. I removed the cutter handles so there shouldn't be any pressure there. |
| Author: | bigDsmith [ Mon Jan 09, 2012 11:52 pm ] |
Thanks kevin f |
| Author: | kevin f [ Mon Jan 09, 2012 11:54 pm ] |
bigDsmith wrote: Thanks kevin f Yep ive delt with that before. your welcome. |
