It is currently Sun May 03, 2026 5:11 pm
 Post subject: Empi vs Porsche 914
PostPosted: Mon Oct 03, 2011 9:14 am
I need to change the rear drums to discs, I have various calipers and the fab skills to make the brackets, the question is which discs? I have the option of Empi 1 piece discs/hubs or Porsche 914 discs and seperate type 3 hubs, the price is approx the same, whats the better option?
 Post subject: Re: Empi vs Porsche 914
PostPosted: Mon Oct 03, 2011 9:30 am
914 without a doubt. I have heard and seen too many Empi (junk) rotors stripping out the splines. You will have a tough time hurting the type 3 drive hub. I had this same set up in my first car, had no problems. This is the same set up I have planned on my Funco single seater. Some machine work is necessary to fit them together, the outside diameter of the drive dub needs reduced some to fit inside the 914 rotor hat.
PostPosted: Mon Oct 03, 2011 9:34 pm
Anyone have pics of this setup?
PostPosted: Tue Oct 04, 2011 3:11 am
Pics here:
http://martinsswbratrestoration.blogspo ... th-mk.html
I looked through my box of calipers and I have a set of the mk4 Golf rear calipers, just wonder if they're powerful enough for use on a woodsbuggy....
PostPosted: Tue Oct 04, 2011 8:05 am
i got a buddy that runs them and they work good.
PostPosted: Tue Oct 04, 2011 8:58 am
Thanks, that saves me $$$$
PostPosted: Tue Oct 04, 2011 2:27 pm
Should be, so long as the master cylinder is sized right.
PostPosted: Wed Oct 05, 2011 6:10 am
or the pedal ratio..
PostPosted: Wed Oct 05, 2011 8:18 am
...or the disc is big enough....or the pads are grippy... :D
You can make anything work with the right setup tbh, I've got motorbike calipers on my daily :shock:
