nissan sentra brakes
http://woodsbuggy.com/phpBB3/viewtopic.php?f=10&t=11862
Author:  dirtdobber [ Sun Jun 12, 2011 9:39 am ]
Post subject:  nissan sentra brakes
What year model brakes to use ??? front or rear????? Im putting these on rear of buggy. ive seen alot of people using these ,they allways so they cant remember what yr,and etc. thanks for return info., dirtdobber
Author:  Huey [ Sun Jun 12, 2011 10:41 am ]
Post subject:  Re: nissan sentra brakes
I used 91 Nissan Sentra front calipers.
Author:  A. Cole [ Sun Jun 12, 2011 2:07 pm ]
I think mine are 86 fronts.
Author:  RaceBugg1098 [ Mon Jun 13, 2011 12:04 pm ]
I dont remember the year but those sound right to me! I love those brakes, like 'em even more than my wilwoods!
Author:  Tackleberry [ Sun Aug 14, 2011 10:29 pm ]
I have late model corvette brakes now and i ended up brakeless today at turkey bay goin down hills with no brakes is not really fun lol.....i want to change to the sentra callipers what kind of mounting bracket do i need i was told that alot of people run these and they are really great
Author:  ridenrace6 [ Mon Aug 15, 2011 12:19 am ]
i got mine from the local carquest (and like them pretty good) but im pretty sure these are the same ones from autozone
http://www.autozone.com/autozone/parts/ ... 1_0_0_2243
all you need to mount these are a piece of 2" flat bar at least 1/4" thick and drill 2 holes and weld it to the trailing arm then bolt the "floating" caliper and bracket to the the flat plate
of course you need to "fit" everything as you go and try to get the caliper as low or close to the top edge of the rotor as possible without it scrubbing to get as much of the pad as possible to make contact with the face of the rotor ( this is true for any rotor and or caliper setup )
make sure to get 4 bolts to mount the threaded "floating" caliper bracket to the welded on flat bar bracket, it seems like they some kind of oddball metric size or thread pitch but i cant remember what it was
also i mounted the left caliper on the right and the right on the left to get the bleeder plugs "on top"
Author:  wheelieup [ Mon Aug 15, 2011 9:37 am ]
mine are off an 89 sentra but i just did a set for a buddy and i had gotten his off of a 88 nissan pulsar. they are the same.id imagine anything pre 93 is the same.just make sure it has non vented rotors.
Author:  Eric DeBord [ Thu Sep 22, 2011 7:23 pm ]
Buyers Guide
Make Model Engine Year(s)
Datsun Sentra 1982 - 1982
Nissan Pulsar 1.6 L 1597 CC L4 SOHC 1987 - 1989
Nissan Pulsar 1983 - 1986
Nissan Pulsar 1990 - 1990
Nissan Pulsar NX 1.6 L 1597 CC L4 SOHC 1987 - 1989
Nissan Pulsar NX 1983 - 1986
Nissan Pulsar NX 1990 - 1990
Nissan Sentra 1983 - 1990
Author:  badbrad [ Sun Sep 25, 2011 9:26 pm ]
I run 89 sentra brakes on mine and they work great. They've never felled me yet.
