It is currently Mon May 04, 2026 1:07 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 30, 2013 11:05 pm
2800passat wrote:
Loose axle nuts will let the rotor walk back and forth and move your pads out just enough to give grief.Same with wo out bearing housings and inner ball bearrings. Same with slightly bent stub axles and warped rotors.Trash and dirt between rotor and hub. I have put feeler gauge blades between the roller bearings and the housing to take up "Up and Down slack". Frozen rusty calipers won't bleed out from my experience. Just my 2cents.
axle nuts are tight , bearings are good brand new brakes no stuff between the rotor and hub( one peace rotor and hub assembly)
PostPosted: Tue Apr 30, 2013 11:06 pm
Did you pinch hoses yet?
