It is currently Mon May 04, 2026 4:02 pm
PostPosted: Mon Mar 29, 2010 11:05 am
Need to get calipers for my front Brakes. I run GM brakes on the rear and need a smaller piston floating caliper for the front. I am leaning towards the Sentras unless some one has a better sugestion.
PostPosted: Mon Mar 29, 2010 11:21 am
Sentra. I think its about '84 up to '89. They switched to vented rotors around '90. The caliper looks the same except the slot where it rides over the rotor is wider, and the pads can fall out after they get about half worn out when running them on a nonvented rotor. Find ya a Sentra in the boneyard with nonvented front rotors, and thats the one.
PostPosted: Mon Mar 29, 2010 1:05 pm
I may have a set of 2 piston Wilwood calipers for sale in the near future. I am going to go to 4 piston Saco's in the rear. The Wilwoods would work well for the front. They do use a 3/8" Rotor.
PostPosted: Mon Mar 29, 2010 1:17 pm
Ody, I was told I cannot use the stock universal VW ones that I have because the stick out to far on the tire side. I bought stock 5 lug VW front rotors and Brian Drew said I will need a floating caliper of some kind. If what you have would work I am game.
And thanks larry, that was the info I was looking for.
PostPosted: Mon Mar 29, 2010 1:52 pm
A 2 piston caliper applys force from both sides of the rotor and would be classified floating. A single piston caliper needs to be able to slide in its mount and would also be clasified as a floater. If the rotors you have are 3/8" then you can make these work as long as your rim offset allows room for them.
PostPosted: Mon Mar 29, 2010 2:14 pm
The way the rotor is set up it won't allow room for that style. Thanks anyways.
PostPosted: Mon Mar 29, 2010 2:39 pm
PostPosted: Mon Mar 29, 2010 3:43 pm
PostPosted: Mon Mar 29, 2010 4:04 pm
Whats the distance between the inside of the rotor and rim mounting flange? I will measure the Wilwood Calipers for fit.
PostPosted: Mon Mar 29, 2010 6:39 pm
1-3/8 and the lugs will occupy some of that as well.
PostPosted: Thu Apr 01, 2010 1:01 pm
Looks like my bone yard has these, gotta go pull them. Anyone mounted these or similar rotors on the front? I'd like to see some pictures of the mounts. I'll take rear pics if thats all that has been done. No since re-engineering the wheel from scratch, just a little at a time. :wink:
PostPosted: Sun Jul 18, 2010 8:05 pm
nitro did you every get your front brakes on im working on the same rotor if so can you post some pics thanks
PostPosted: Sun Jul 18, 2010 10:37 pm
Got the mounts done on one side, havnt made a twin yet, lol.
