It is currently Sun May 03, 2026 5:11 pm
PostPosted: Fri Nov 27, 2009 10:46 pm
Not sure what the fitting size is for the sentra calipers, I hase some lines that I tried and nothing fit. Do I have to run a banjo bolt then brake line. Any help with the thread pitch/size would be great. Thanks, Adam
PostPosted: Sun Nov 29, 2009 1:52 am
i hope I am right, banjo, 10mm x 1.25
PostPosted: Sun Dec 06, 2009 5:20 am
not sure . we just use the rubber line from the car. and bought the steel line at autozone the jap ones.
PostPosted: Mon Dec 07, 2009 11:26 pm
Well I was wrong... Its 10mm x 1.0 I got it figured after buying some bolts at the hardware store. I've got a bit over $200 in lines/fittings in my car :( All the fittings add up quick. I know its not nearly as much as some but its plenty for me.
PostPosted: Tue Dec 08, 2009 10:34 am
The small things can break a guy in a new build but at least you got a bad ass car to show for it
PostPosted: Tue Dec 08, 2009 10:39 am
My Corolla calipers had banjo fittings, but I used a standard VW hose and put the brass washers from the toyota hose's on the VW hose and had a very good seal. Now I am upgrading to Wilwood and ordered some adapter fittings from Appletree,,,,CB Performance has adapters also.
PostPosted: Tue Dec 08, 2009 8:46 pm
thanks aboone
I got everything from speedway motors. They have a ton of stuff with a great catalog that makes for great reading material :D
