It is currently Mon May 04, 2026 4:02 pm
PostPosted: Wed May 29, 2013 8:35 pm
wheel bearings on my T trailer went COMPLETELY out sunday afternoon and I'm going to have to replace drum and all. The brake drums/wheels & wheel bearings on trailer are VW and I'm not sure whether to order bearings for K/P or ball joint?? I'm at work right now and don't have a pic of the brake drum removed but I'm posting one below of the drum hoping someone can identify what I've got and most importantly what I NEED!! From what I gather the spindle is different diameter on B/J & K/P? Thanks,
PostPosted: Wed May 29, 2013 8:45 pm
That's easy 5 lug is kingpin and 4 lugs is balljoint good luck
PostPosted: Wed May 29, 2013 9:50 pm
easy enough, thanks! I haven't had to fool with any brake drums so I'm clueless on that. I've got discs on rear and spindle mount wheels on front of rail so never had to familiarize myself with drums. I found some ID&OD dimensions of wheel bearings on appletrees website and wrote em down to compare with the GOOD side still on the trailer
PostPosted: Fri May 31, 2013 5:24 pm
Not always.
66-67 VW's were ball joint and wide 5 lug pattern.
Had a smaller ID on the inner bearings than the later ball joint spindle bearings too.
If those rims are the originals I'd say they are from a 66-67 ball joint.
Earlier 5 lug rims from the king pin cars did not have the slotted vented wheels.
Especially if the dust cap goes over the machined lip on the drum.
The king pin dust caps went into the drum rather than over.
PostPosted: Fri May 31, 2013 10:01 pm
I agree with Gary ... looks like a ball joint dust cap . Is the spindle nut a jam nut style or a funny locking nut with a allen bolt in it ?
PostPosted: Fri May 31, 2013 11:20 pm
its got the locking nut with allen bolt. after doing some research I'm agreeing with yall on being 67/68 ball joint
PostPosted: Fri May 31, 2013 11:35 pm
Yea I thought 67 was the only year that was balljoint with 5 lugs I got
One of the Layin in the yard. My buddy's t trailer has that type of spindle
On it with a bent spindle but I guess it make scent a balljoint spindle
Would be easier to weld on than a kingpin I gotta replace a spindle
On it
