It is currently Mon May 04, 2026 4:02 pm
 Post subject: master cyl size ?
PostPosted: Wed May 08, 2013 6:01 am
i see some people run 3/4 & some have 7/8 bore master cylinders, could someone please educate me on the pros & cons of each size?
ya cant beat fun!
 Post subject: Re: master cyl size ?
PostPosted: Wed May 08, 2013 11:34 am
bigger the bore the more/quicker fluid gets pushed. Usually MC bore size is related to the piston size/quantity in the caliper.
has left the building...
PostPosted: Wed May 08, 2013 2:07 pm
ok so what factors does a person need to know to determine what size he shoud get?
ya cant beat fun!
PostPosted: Thu May 23, 2013 10:08 pm
i have to use a 1 inch t make my breaks work well now they are great and to know what you need i say if its not the vw calliper go on and get the wilwood 1inch
PostPosted: Thu May 23, 2013 10:11 pm
2 single piston rears then a 3/4 will be fine. Once you go to 4 piston or add front brakes then a 7/8 master. if they are all 4 are 4 piston then 1".
PostPosted: Fri May 24, 2013 12:21 am
the 1" bore works good on chevy brakes cause it is one LARGE piston.. takes alot of fluid to move it and the larger bore helps to keep from having a spongey pedal 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
