It is currently Mon May 04, 2026 2:39 pm
PostPosted: Sun Feb 10, 2013 11:37 pm
I need to replace the rear brakes on my buggy. Its IRS 4 lug bolt pattern. My question is for what year and make do i need to order parts for. Like wheel cylinders brake shoes and little odds and ends. thanks in advance
I may not know alot about working on cars, but I know enough to be dangerous.
PostPosted: Sun Feb 10, 2013 11:56 pm
Why not just order a disc brake kit instead of wasting money on drum?
"IT IS WHAT IT IS"
PostPosted: Mon Feb 11, 2013 12:33 am
x2 what he said!
PostPosted: Mon Feb 11, 2013 12:35 am
irs is the same from '68-'79
PostPosted: Mon Feb 11, 2013 12:39 am
I have a full set, Backing plates, new wheel cylinders and hardware. Les than 200 miles on them. Ready to bolt up. I will take $50.00 plus shipping. Here are some pics. Drums are separate. I will even throw some extra springs, clips, and whatever drum hardware I have in on it. PM or Text 423 335 3159
PostPosted: Mon Feb 11, 2013 12:53 am
If you can find an old type 3 sqareback the whole drum backing plate and everthing will bolt right up. And a superbeetle front wheel cyl and shoes are the same.RTV the drum to the backing plate and then slice them loose the next day after it dries with a razor blade and they will be water proof. Also rtv the adjustment wholes.But I'd just go disc.
PostPosted: Mon Feb 11, 2013 2:45 pm
can you guys poin me to a link for disks. i have a few calipers layin around. and my trailing arms already have caliper brakets on them.
PostPosted: Mon Feb 11, 2013 5:38 pm
http://dansperformanceparts.com/buggy/t ... ytcbh1.htm
"IT IS WHAT IT IS"
PostPosted: Mon Feb 11, 2013 5:39 pm
http://dansperformanceparts.com/buggy/t ... onents.htm
"IT IS WHAT IT IS"
PostPosted: Thu Feb 14, 2013 8:56 pm
Where are you from? Any buggy shop would have rotors or disk brake kits. A lot of different online stores including eBay that likely have them.
