It is currently Mon May 04, 2026 4:01 pm
PostPosted: Thu Dec 27, 2012 11:32 pm
Like the Subject says. My buddy just bought a buggy with disks on it. But we don't know what the calipers are. Here is a pic. The only number we found are 288 or 233. The bleeders have been removed and replaced with plugs. In the pic there is a bolt head next to the bleeder. The brake line goes into the center of the piston. And i have no idea what the shinny metal tabs are for.
Any ideas? :?:
PostPosted: Fri Dec 28, 2012 12:31 am
68 ford fairlane. just joking. that is a tough one but i think i'm close.
PostPosted: Fri Dec 28, 2012 3:14 pm
lol :lol: Thanks
PostPosted: Fri Dec 28, 2012 8:36 pm
passat2800 came very close but not exactly thats a 60's ford caliper from an LTD or Thunderbird. the bolt next to the bleeder is a pipe plug thats where the line used to go before someone drilled and tapped to put the line where it is now. wish i could tell you an exact part number but im very certain thats what it is. as for the shiny tabs im not sure those are not stock.
PostPosted: Fri Dec 28, 2012 8:50 pm
this should be the pads
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_brake-pads--front-wearever-silver_5752353-p?navigationPath=L1*14921%7CL2*16463%7CL3*15694#
PostPosted: Fri Dec 28, 2012 9:04 pm
Thanks alot hpfreak. That helps a bunch. Woodsbuggy people are the best :wink:
PostPosted: Fri Dec 28, 2012 9:14 pm
no prob but just dont hate me when im wrong. its not like i have grandmas old ltd in the garage but ive seen them a million times. I posted the pads to compare to yours to make sure before you go ordering parts or anything. the caliper i found at advance was exactly the same except the line went to the bottom with a banjo style fitting youll just have to look around to figure your exact model and year.
PostPosted: Sat Dec 29, 2012 12:11 am
I figured passat2800 would chime in. from what I have heard and seen from him, I figured this was right up his alley. I really appreciate all the info everyrone puts in.
PostPosted: Sat Dec 29, 2012 2:05 am
remember ,I am the junkyard dog lol. you'll probably see me at pull a part b4 you will see me at the titty bar,lol. Let's see pull a part closes at 5, happy hour at Sammy's is 6...
