It is currently Mon May 04, 2026 11:37 am
 Post subject: rebuild kit for bugpack
PostPosted: Thu Nov 29, 2012 4:03 pm
Where can I get a rebuild kit for a bugpack single arm cutter?
Ive looked everywhere it seems
PostPosted: Thu Nov 29, 2012 5:14 pm
Might compare it to a Jamar. It seems like I read somewhere that they were basically the same. I'm pretty sure the Bugpack kits are discontinued now.
It might be easier to just buy a new cutting brake. They aren't terribly expensive and then you will easily find parts for it.
PostPosted: Thu Nov 29, 2012 7:06 pm
Best of luck and check the bore if it is pitted at all junk it and elect for a cnc.
PostPosted: Sat Dec 01, 2012 1:59 pm
haha, Yea im gonna try to find a cnc cutter but I doubt i can afford one.
PostPosted: Sat Dec 01, 2012 3:30 pm
It should be less than $120.00. I think I paid $95.00 for mine about 4 years ago.
PostPosted: Sat Dec 01, 2012 4:46 pm
try southern buggies or drews off road
PostPosted: Sat Dec 01, 2012 10:00 pm
Have you taken it apart yet? If it just needs a new cup seal you can get one at NAPA, should be the same seal used in wheel cylinders.
Good Luck
Kenric
PostPosted: Sat Dec 15, 2012 11:49 pm
I took it apart and the first o ring was wore flat so I tried to find one and couldnt so I took a bit larger seal and cut it at a angle and glued it together seems to kinda work it doesnt leak out of the front anymore I just have to bleed it out I still want a different set.
