It is currently Mon May 04, 2026 1:07 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
 Post subject: Re: Wilwood calipers?
PostPosted: Sat Mar 31, 2012 10:54 pm
OK so think ima go sentra calipers....Question though. i put in 86 and 92 in a search at autozone....86 is cheaper, and $5 core charge. 92 few bucks more, BUT $25 core...Picture shows the identical caliper...So im goin 86 unless theres reason not too!?
"IT IS WHAT IT IS"
PostPosted: Sat Mar 31, 2012 11:08 pm
The s-10's are just under 1" from the rotor just an FYI. Can pull the cutter with one finger at throttle and lock it. My gias I thought I would snap the lever off, and I tend to pull hard. But always heard good things of the wilwoods, i run them up front.
PostPosted: Sun Apr 01, 2012 9:31 am
thanks nitro, Ima do a bunch of measuring today. and make a decision for sure.
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 2:50 pm
Well I ended up gettin 2 calipers from a 94 sentra, and 2 from a Vw cambrio . Think Ima go with the VW ones as their design is simple compared to nissan. lol PLus the say made in germany 8)
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 3:36 pm
From what I hear you should be happy. Just another FYI, my rear brakes on my 09 Dodge Grand Caravan are single plate rotors roughly same thickness we use. And it has the cable for E-Brake. Think I may switch to that setup at some point.
PostPosted: Sun Apr 01, 2012 7:17 pm
e brake cable is something i would stay away from, gona get the line lock . was outside messin around a little checking things out, VW calipers seem like they are gonna work out good. Just havta weld on the bracket , drill and tap the holes. done. :D
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 7:20 pm
....Kinda thinking about buying the front rotors and get 4wheel disc goin since im already in the process
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 7:29 pm
I put the good fronts on mine and it is alot of piece of mind at wellsville. Just havnt been back to give em a good test yet. But on a wet weekend its easy to get spooked with just rears.
PostPosted: Sun Apr 01, 2012 7:37 pm
I never use to have fronts hooked up.then I went to wellsville and I knew right away I would not go back with out them if I had my boy in it with me.I was riding with everybody else and they had fronts and was stopping on stuff I couldn't.just about had a few close calls with plowing into someone.since I have them on the front on a separate handle I love them,can't believe I had waited so long to do it.Chad :mrgreen:
PostPosted: Sun Apr 01, 2012 8:29 pm
X2 Gasman
PostPosted: Sun Apr 01, 2012 9:19 pm
Chad that's why the paints rubbed off the back of all our buggies ! Lol
Oh wait that's from pushing them vw's home !!!! :twisted:
PostPosted: Sun Apr 01, 2012 9:21 pm
lol...So it took wellsville to make ya want front brakes!? funny stuff right there! Im thinking about it But we'll see. If I do it will all be on the pedal, atleast til i get money to seperate with the single handle.
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 9:23 pm
Jason, This post is about brakes. I will not allow a suby, vw battle started here!!!! lol thank you :lol: :lol: :mrgreen: I ran around down there with just drums for a year or two back in the day . That always got the heart pumpin!
"IT IS WHAT IT IS"
PostPosted: Sun Apr 01, 2012 9:29 pm
8) 8) Thought that was between us? :mrgreen:
